What is the difference between Camera Positioning found under Device Settings and Video Settings. They both have a zoon feature but I am sure when to use which?
I am finding when I update the cameras angle in Video Settings or Camera Positioning the display changes away from that set in either when trying to add activity zones?
If my cameras are wired which should I only use?
Thanks all.
i would not recommend using any pinch and zoom settings or using activity zones if your after reliability, just my opinion and good luck..
Looks like one sets up "zones" while the other controls the live view.
Just another user
