Bought Arlo Pro 2 cameras and have weak WiFi connection. How to return?
Hi. If I was to go ahead and buy the Arlo Pro 2 Cameras and have weak WiFi connection, where do I stand with returning them? My router is up to date, 55mbps fibre optic and manages fine with powering my smart devices around my house. Thanks.
Depends on where you buy from and their return policy....
As to the weak wifi, the only true way to expand coverage area is by adding bases. ( no limit on any account level of bases )
Tho, Most do find the centrally located base unit seems to cover the homes.
Alot depends on the materials your home is bulit with as with any wifi signals.
