- 2
After Dec 2 update, whenever you open Arlo, or select any of the options within the app (mode, devices, library, etc.), a big solid notification that just says "Arlo" is popped across the top of the screen for every action performed. See attached screen shot. This was not happening prior to Dec 2 update.
Running latest Android 10 with latest security patch level: December 5, 2019.
I just found this "community" after searching for a better way to get support, since Arlo seems to be totally useless.
I have a 3a XL and have had the same annoying issue starting about the same time.
I had posted this in another area of the forum and an Arlo support person said it was being escalated to the development team. We'll see what happens but I won't hold my breath.
I have gotten no app update today at all.
I notice that Google app updates sometimes take time to make their way to my notifications. I manually checked on this app and found an update.
After updating it just now it DOES appear that the problem is resolved.
- 2
