Connecting issues
I have run my Basestation and cams for a mounth now , and what i seen is that the Base station goes on and off in connecting to the wifi. I got a pretty good new router and it seems to be stable. My cams get offline now and then and when i look at Base station its amber light goes on and shift to red blink after like 2 minutes. In long periods everything have worked fine , but now its totally jamed. I had the Base station flicker on and off at the light Amber and Red blinking light. I have tryed to reset both the Base station and the router but it turns back on this state. Amber light goes on 2,5 minute and then turn red blink a few minutes and so on. The on and off thing was not so frequent from start but it got worse and worse. And now its offline all the time. =/
You didn't tell us which LED is amber/red (I've never seen red, only amber). That could make a difference.
