Connecting 2 base stations together
  • 1 Reply
  • 1000 Views
Bettertraffic
Hi,
How do I connect 2 Arlo Pro base stations together?
Thank you.
Best,
G
You use ADD device for the second base, then remove some cameras  then resync them to the nearest base ( or best signal, which usu is the nearest )
  • 1 Reply
  • 1001 Views
