  • 1638 Views
DirkDH
Hi, I've connected my arlo pro2 to an Arlo solar panel. Past months it worked well. Now since a few days it mentions that there is a charging issue. I've already take it off, and reconnected it but message comes back. Just to inform: Temperature has dropped last days around 0°C. On phone it mentions also an orange exclamation mark. Anybody who knows what to do to solve this?
The solar panels WILL NOT charge below freezing.... this is built into the camera as a preventative measure so damage will not occur to the battery pack
When the camera comes above freezing it will allow it to charge.
PS
camera should still work down to at least -4F
I recommend a charge tube and two extra batteries over a solar panel ( if camera is reachable )
due to the fact in winter it may not charge AND you get a true 100% charge in batteries ( they last 20% longer as in camera max charge is really 80% ( done again to prevent overcharging ))
DirkDH
Thanks a lot for the quick reaction. Could you clarify what you mean with a charge tube?
The thing is it is not easy to switch batteries each time because I have to take a ladder to reach the camera. That's why I chose the solar panel. Thanks for your information.
Arlo Accessory - Charging Station | Compatible with Pro, Pro 2 | (VMA4400C)
  • 1639 Views
