Clear all notifications on Android opens Arlo app
  • 25 Replies
  • 9005 Views
  • 7 In Conversation
debugger919
When I press "CLEAR ALL" notifications, the Arlo Secure app would open and requires me to login, this did not happen before, please fix it, very annoying.
Android 12
App version 4.0.2.1_28506
Released 12/09/22
25 REPLIES 25
ShayneS
May I ask which troubleshooting steps you have performed so far? I don't want to suggest anything you have previously performed.
debugger919
I tried to force close the app and re-open it, haven't tried to uninstall the app as I'm afraid of losing all the existing settings.
ShayneS
@debugger919
You shouldn't lose any settings by removing and re-installing the app. I have done it many times.
debugger919
I uninstalled and reinstalled the app, and this is still happening.
ShayneS
Do you happen to have a screen recording/video of the issue. You can find instructions to achieve this here: https://support.google.com/android/answer/9075928?hl=en
debugger919
where should I send the video to?
You can put it into cloud storage (icloud, google drive, onedrive, dropbox,...).
Then post a download link here if you are willing to make it public.  Or send a PM (private message) to @ShayneS with the link if you want to keep it private.  Click on the envelope icon in the upper right of the forum page to send a PM.
NancyS24
I am having the same problem on my Android phone. It started after the last update when the logo changed. The Arlo app opens any time I do "clear all" for notifications. There is no way to take a screen shot of it or whatever.
NancyS24
Except mine does not make me log in again, it just opens the app.
ShayneS
@NancyS24
Are you able to use this method Record your phone screen
  1. Swipe down twice from the top of your screen.
  2. Tap Screen record .
    • You might need to swipe right to find it.
    • If it's not there, tap Edit and drag Screen record to your Quick Settings.
  3. Choose what you want to record and tap Start. The recording begins after the countdown.
  4. To stop recording, swipe down from the top of the screen and tap the Screen recorder notification .
Find screen recordings
  1. Open your phone's Photos app Photos.
  2. Tap Library and then Movies.
alikhad
I'm having the same issue since the last update. When I try to clear the notification (swipe down, then swipe left) as you would with any other notification, it opens the Arlo app (no login required). I'm in Andriod.
Swipe down to get to the notification, right? I then swipe right to clear it - never tried left.
alikhad
I confirmed it doesn't matter if you swipe left or right with any notification, it clears it either way. Not the Arlo notifications though. I find that it doesn't always open the Arlo app when clearing notifications, but even the times that it doesn't open the app, the screen goes white like as if it's trying to open it but doesn't.
Any fixes for this coming?
ShayneS
@debugger919
Does this occur on the latest version of the Arlo app v4.1?
debugger919
This is the version I have:
4.1.0_28513
alikhad
I also have version 4.1.0_28513. No other updates are available.
ShayneS
Just double checking, Are we still experiencing this issue with version v.1?
debugger919
Yes still happening in 4.1.1_28514
alikhad
Mine seems to have stopped doing it and is now working normally.  I will continue to monitor and will report back if it returns.  Thank you.
ShayneS
@alikhad
Oh that's good to hear, let me know if it occurs again asap.
debugger919
This problem is still happening to me, in the latest version.
ShayneS
@debugger919
Thanks, I let the team know and I will update the thread as soon as possible.
torga3ight
I am also having this issue since the update. Any closure of push notifications swiping any direction, or clearing them all at once, opens the Arlo app screen. I'm basically closing the app about 100 times a day these days. Has there been a fix to this? it's been happening for over a month now.
I have Arlos, Arlo Pro 2s, Arlo Pro 3s, and arlo essentials. Running about 12 cameras on the paid plan.
Thanks in advance!
debugger919
The latest version 4.2.1_28524 has fixed this issue.
  • 25 Replies
  • 9006 Views
  • 7 In Conversation
