Hi I'm recharging my batteries for the first time. Both down around 20% or less. Plugged in the back door one first. When I view devices on PC it shows as recharging but both now display the same %. Have refreshed but the same thing. Is this just a display issue? Also how long does it usually take to do a full recharge? Of u have any ideas it would help.
Many thanks
I find they take about 90 minutes to fully charge. What percentage is the back door one showing?
Great thanks for the info. The back door is up to 63% now and the front door is showing the correct (low) % so I guess my problem is solved. I was unable to find a timeframe anywhere so good to know.
