  • 2 Replies
  • 1358 Views
Matt155
Charger does not work had product less than a year. Will net hear send me a new charger?
Reallyconfused
Virtuoso
Virtuoso
Yes, mine is bad also. It’s the dual charger with the yellow lights which turn green once the battery is fully charged. Only problem is that only one light/side does turn green. The other side will stay yellow for ever. I have to check the battery voltage manually to be sure it’s charged. $75 worth of crap in a way.
You can contact support to invoke your 1 year warranty. Alternatively, use another charger that support both 5v and 9v outputs.
  • 2 Replies
  • 1358 Views
