  • 2 Replies
  • 1643 Views
gpmike
I have setup the arlo pro 2 and everything works fine but afer a session timeout while setting up I cannot login into the website above.  I have enabled the flash player in chrome which it complained about.  Occasionally complains the password is incorrect when it is not, but mostly the webpage just blinks and nothing happens.  Also deleted all cookies with 'arlo' as a keyword but no help.
Windows 10 with latest chrome
Recently some antivirus/firewall software has caused this to happen, especially Kaspersky. You can try disabling the software to see if Arlo logs in. If so, whitelist https://arlo.netgear.com in the software settings.
gpmike
Thanks Guru...yep Kasperski was the culprit.  Interesting of the many webservers I visit only this one needs exclusion.
  • 2 Replies
  • 1644 Views
