Cannot login to https://arlo.netgear.com/#/log. Using Kaspersky.
  • 14906 Views
gpmike
Beginning 2 days ago cannot login from a PC
After clicking the LOGIN button - button dims and nothing happens
Windows 10
Kaspersky
Chrome - cleared cache and cookies - FAIL
Tried Edge - FAIL
Kaspersky has caused issues in the past but haven't heard of recent problems. Try disabling it first to see if that helps.
gpmike
Kaspersky is the culprit.  I had disabled web-virus protection after posting this.  Login OK, enabled and still working?
Sigh!!!
gpmike
The only website I have trouble with is Arlo.   Previously the information in the userid/password was garbled but if I clicked login twice it would work.  Now it doesn't work unless I disable Kaspersky Protection/Web-antivirus.  Entered the arlo website into the trusted URL of Kaspersky - still fails.   What is so unique about this website login that drives Kaspersky nuts?
  • 14906 Views
