  • 1816 Views
martyee
I bought a new camera for my Arlo Pro 2 system and tried to sync it to the base station using the app and just the sync button method and i couldnt get it to work after many tries.
Eventually i just decided to reset the base station to default and try again, and i could sync all my other cameras again fine, but the new one still didnt work. Blue lights flashing and exact same method... help!
VMB4000v3 - 2 x Arlo Pro 2 and 1 x Arlo (H7)
+ 1 new Arlo Pro 2
Is the battery fully charged?
Did you also try adding the camera with https://my.arlo.com on a PC?
martyee
to 100% at the point of syncing? likely not, but would have been over 90%. Does it have to be?
If the battery is too low, then it might not sync.  But 90% should certainly be fine.
If you aren't certain of the charge level, just swap batteries with a different camera.
Another option is to contact support: https://www.arlo.com/en-us/support/contact.aspx
  • 1817 Views
