One of the arlo is not giving me a picture it’s a blank screen
This is when you attempt to live-stream the camera? Or when you play a video? (or both)?
I am having the same issue. Camera has been working fine for 2 months, all of a sudden I go to look LIVE on one of the cameras and its a blank white screen, showing nothing. I looked at thinking its covered in snow but its not, its plugged in to the power source, blue light is still on, battery at 100%. Tried turning it off and on, same result. After one hour I can faintly see a partial picture in one corner. Not getting any motion detection.
Model is Arlo Pro 2 - VMS4430P - 4 wireless camera set
Does it work normally if you bring it indoors (fairly close to the base)?
