I'm getting pretty sick of ARLO and it's menus. The menus are horrrible! Needs to be easier to set up my cameras. It used to be easy 2 years ago, but now I can't find anything I want>>>like how to set up specific zones in the field of view for motion detection. How to change the time of recording after motion is detected. Now I can't view live images from my cameras because I have to download the newest version of ADOBE...which I did three times now and it still doesn't work. What are you guys doing at ARLO?
That message is a mistake and is misleading.
Here is how to fix it in Firefox:
Re: Cannot view Live Feeds - Flash problem AGAIN! - Arlo Communities
Just another user
Hey BeefFlaps,
To also add on, to set up activity zones, you can read here on how to set this up: What are activity zones and how do I create them?
And you can read here to learn how to change the recording duration: How do I adjust Arlo video recording length?
