Can a replace existing flood lights wiring with arlo 2 camera
Retired_Member
Not applicable
2019-12-23
02:18 PM
Is there a way to use the existing wiring from a flood light to power up the arlo pro 2 camera. If so please explain how.
If not, how would you set up the arlo pro 2 camera with electric outside. I currently have no outlets outside.
You'd need to tap into the floodlight's wiring to create a new outdoor outlet. The cameras need a USB charger (the outdoor one in your case) to operate.
Retired_Member
Not applicable
2019-12-29
06:20 PM
Is it better to put the outlet outside or inside
The fact that you are asking the question suggests that you probably should contact an electrician to do this work for you.
