Can I use Pro 2 inside looking out the window?
  • 2 Replies
  • 1472 Views
Samj
Can I use the Pro 2 inside looking out the window? The area is illuminated at night.
Thank you.
Unfortunately the motion detection won't work since it uses a PIR detector. If you had another camera outdoors, you could use that to trigger the indoor camera, too.
Ceanag
Turn of night vision then the infra red lights wont reflect back from the glass.
If your exterior is illuminated you can still get reasonable vision at night although it tends to be black and white.
  • 2 Replies
  • 1473 Views
