Three of my 4 Pro2 cameras starting showing odd streaks. It almost looks like a swarm of bugs but when I took a visual look there is nothing there. Temperature went down to 39 tonight. Could that be a problem? I tried resetting the base and turned the cameras off/on. The attached video is at night.
Firmware 1.12.2.5_240_59657e5, Base VMB3010r2
Any ideas on what is wrong or how to fix?
Camera firmware 1.125.13.0_31717
@scrapitmom wrote:
Three of my 4 Pro2 cameras starting showing odd streaks. It almost looks like a swarm of bugs but when I took a visual look there is nothing there. The attached video is at night.
FWIW, there is no video attached to your post.
But this is actually normal. The infrared NightVision mode will pick up particles in the air that you can't see, because the particles are a bit warmer than the air. Also, the temp of the air itself isn't constant - so wind can also trigger the sensors. There are quite a few posts on this in the forum.
Hmm, not sure why the video didn't go through. I'll try again. BTW, the problem was gone in the morning when it warmed up a bit so I'm guessing this is weather related. The white lines were like a blizzard.
Seems like when I use the 'attach' icon at the bottom it doesn't keep my video. Any suggestions on how to include one?
You can just put a download link in your post.
