Since you been upgrading App you have made it more useless so we all buy better Deal App because If you use Google Home app the picture is so clear better connection etc and when use Smart Thing app same there but on Arlo App useless can even connect etc
Hi @Raheel
What version of the Arlo app are you using? May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
I am using latest free App that’s why all these problems increase
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
