Have 2 Pro 2 cameras running off Arlo VMB4000 base unit. Both cameras work fine on browser. On phone app, one camera works fine but the other responds to alerts when viewed in library but shows 'offline' on live view with no access to device utilities. Base unit has been reset several times and camera synced to base and app account several times. Also Arlo app has been uninstalled and reinstalled several times. Still the same problem. All running latest software. Any ideas?
Thanks for your help.
Hey Gofer2u,
Try to remove the battery from the Arlo Pro 2 camera that is having the issue and re-insert the battery to see if that helps. And make sure you are running the latest version for the Arlo app.
What phone device are you using? Is this happening when you're on both on cellular data and/or WiFi? Have you also tried restarting your phone device to see if that helps?
Since you're experiencing the issue on just your OnePlus 5T, let me reach out to you via private message to gather some information from you.
