my camera records every minute, how can this be changed?
and it does not record at night, why?
Can you provide some more details like if this problem has just started happening or if you are setting up a new system?
can you detail camera, base station models.
Also, tell us if this is due to motion or audio detection. You might want to check your active mode and deselect audio detection if appropriate. Otherwise, try reducing the sensitivity in the rules.
