Hi Guys,
I got issue with arlo camera recording, I have attached two video link below
Front 1 : neighbour try to pull gutter with force and get the ball, he came to my premises without my permission
https://1drv.ms/v/s!AiMBxhqU7ezfgoEjUL9wEX6yGUi4Uw?e=b2f3ku
Front 2: I didn't manage to get much full footage of his body try to pull the gutter. As you see in footage video, there is another camera (front2).
My question is how shall I adjust the front 2 to get footage, It seems to be there is some issue.
Please advice me.
You can modify your modes and rules (or create a new mode) with cross-triggering.
cam1 detects, cam1 records
cam1 detects, cam2 records
cam2 detects, cam2 records
cam2 detects, cam1 records
Thank ,
I force to record both like you recommend at the moment.
Hopefully it don't disturb each other when both camera detect motions. 😄
