Arlo camera mounts
  • 1 Reply
  • 1595 Views
Geobsum
Beware of the less expensive Arlo wall mounts that all the cameras screw into! They corrode and rust!
Went to charge cameras after 4 months in FL salty air and two cameras screwed into the cheaper mounts corroded and fused together! Tried everything to separate them and took the whole mount down and used vice grips pliers and hammer with no success! The cheap mounts spin making it impossible to unscrew!
The official Arlo mounts are made of a better grade of ss and don’t corrode or rust!
Had to throw away two Arlo pro 2 cameras so the financial loss was far greater than the savings from buying non Arlo made mounts!
ShayneS
Hi @Geobsum
Thank you for providing this feedback! Arlo always suggests to utilize OEM products.
  • 1 Reply
  • 1596 Views
