One camera records locally, the other doesn't. Tried factory reset on cameras and base without change. Still same problem. Only thing left is to delete my account and use a different email I fear. So frustrated with this junk!
Thanks again for input
What base?
Can you confirm that you are talking about Pro 2 cameras? They get 7 days of free cloud storage - is that working?
I have tried cloud recording and same issue as with local recording. Any ideas?
So the camera isn't recording at all? Does it live stream?
@Tones123 wrote:
Yes both cameras are pro 2's, both live stream, one records both local and cloud, the other does not record at all (either local or cloud)
Does manual recording work?
You could try running the motion detection test: https://community.arlo.com/t5/forums/unreadpostspage/post-type/thread/category-id/Arlo
Thanks for your help. Yes manual recording works, but motion detection isnt. Using the tool it does not seem to detect motion, and that may well be the cause. I have set up a detection zone but fear either the camera is faulty, or there is a hidden setting to turn the motion detection on. I could only find the tool setting to adjust the sensitivity. I tried adjusting this and it made no difference.
Don't forget to use the Contact Support link at the bottom here which is the only way to get warranty replacements.
That sounds like a faulty camera.
