How many cameras can Base Station support? Can newer cameras (like Pro 4) be connected?
  • 1 Reply
  • 3122 Views
treaders
Hello,
How many Arlo Pro 2 cameras does the Pro 2 hub support? I already have 4 Pro 2 cameras.
Can newer Arlo cameras be connected to the Pro 2 hub? For example, can a Pro 4 camera be connected to a Pro 2 hub?
Thank you,
treaders
ARLO - VMS4430P ARLO PRO 2 (4 x CAM)
SN: 5TN3057DA009B
https://kb.arlo.com/000062284/What-is-the-difference-between-each-Arlo-SmartHub-and-base-station
Although the Pro4 isn't listed, it connects to the same hubs that the Pro3 and Ultra do.  The Pro4 can also connect directly to your home WiFi.  You will need a paid subscription for cloud storage though (unlike the Pro2).
A base should be able to handle streams simultaneously from 5 cameras.  You can connect more, but if more than 5 cameras trigger you will lose recordings.
  • 1 Reply
  • 3123 Views
