I tried including a video clip of what’s it doing but it won’t let me.
If you think the unit is bad, either return it or contact Netgear support for a warranty issue.
Tho you already did most of what I would suggest, Netgear support may have a better answer
@Dubgreasemonkey, are you using an ios device? Because currently, Arlo is experiencing issue regarding their application. Customers who have an ios device that has the latest app version (2.5.0) are unbale to do live stream on their ios devices. However, when account is accessed on a non ios device, cameras are streaming perfectly fine.
Try to access your account to another device like a computer to check if cameras are streaming.
Yes, this issure really started after we as customers updated the app version to 2.5.0. Right now they are still creating for a fix for it.
