I've been up and down the ladder, on the phone with support, had Comcast out to check wireless signal, Geek Squad installer out to troubleshoot and STILL the cameras continuously go off line. It has been suggested that there can't be any walls between base station and cameras. Really? Aren't these indoor/outdoor cameras? Then it would serve to reason that there would be at least 1 wall between the base and cameras wouldn't it? This product is NOT ready for prime time. In two weeks I have spent more day fooling around with these cameras than I care to remember. In summary, don't waste your time if you value your time.
Get it replaced asap if still under warranty.. Camera or Base could be defective.. Contact Support
I don't know, I totally disagree. Mine have been absolutely perfect over the last month since I bought the six pack. Immediately out of the box they worked flawlessly. Personally, I would check your main router to make sure it is delivering everything it should to the base station. Good luck
Thanks. I’ve tried everything up to this point. Comcast is coming back out today to take another look at signal strength. The battery drain while offline is another issue I’m contending with also. It’s a bit frustrating.
Yes, I understand. It is frustrating when things don't work as they are promoted.
For myself, I used to have AT&T and had a horrible Wireless Wi-Fi signal. It was only 6 megabytes when we tested it. I had called Arlo and they said no way it would work with these cameras. I waited for almost 2 years until finally going to fiber and 300 megabytes speed. My AT&T modem that they had me connected for the 6 megabytes was pure junk as well. I think the new fiber router is much much better. It sounds like your issue is due to signal strength, I could be dead wrong and maybe I'm just lucky to get a good batch of cameras, but I would check everything else, before the base station. I'm not sure if you have enough time to return what you have purchased but I would not hesitate if you find that they are not working for you. These cameras are expensive! I paid a little bit more buying them directly from Amazon opposed to a third-party seller in Amazon, because I did read some posts from users that were negative, however there were much more posts that were positive than the negatives, and I feel sometimes most of these issues are due to individual problems within their own systems or network, and it's not the product that they purchased.. I wanted to be sure that if they needed to be returned, that I would not have to also pay shipping. When you buy directly from Amazon, return shipping is always covered by them. In my case I expected the cameras to not fully be able to work without Wi-Fi extenders placed throughout my home, but so far that has not been the case. My six cameras have never gone offline and they are placed more than 50 feet away from the base station within different levels of my house. My ceilings on each floor are 12 feet high and the router and base station are in my basement. Good luck and I hope you find a resolution to the issue. I know it's frustrating, and sometimes it's not worth the trouble.
My base station has 2 walls and about 140-150 feet from one of my cameras and have had no problems with it. Good luck with it as these are very good cameras.
