  • 1 Reply
  • 1069 Views
Retired_Member
Not applicable
The camera indicator is glowing solid orange! Why?
Streak2
Master Master
If you are referring the to light on the camera then this is not one of the documented conditions.
Remove and refit the battery to reset the camera and see if that works.
If you are referring to the light on the base then it means that it needs to claimed by adding the base as a device.
  • 1 Reply
  • 1070 Views
