Arlo Pro 2 reboot loop
  • 4 Replies
  • 2096 Views
Mark1236
Hi I have an Arlo 2 pro 2 camera system.  When opened from box followed instructions and all worked fine until it prompted via the app to update firmware on base station.  Since that time the base station has been caught in a reboot loop and unable to connect.  Any ideas?  I am unable to reset by holding done reset button at back of machine.
Streak2
Master Master
Mark1236
I cannot reboot, holding down reboot button will not seem to have any effect.
Streak2
Master Master
Disconnect power from the base. Wait a bit then reconnect power. If needed then try the 10s reset as mentioned above. If still no joy then you'll need to contact support.
Mark1236
Thanks for the suggestion.  I've tried that also but no joy.  Been on phone to support, I think they are going to send a new base station out.
  • 4 Replies
  • 2096 Views
