Showing results forÂ
We have a set of Arlo Pro 2 cameras that I am getting ready to install.
I’d like to install one on our front porch to cover the front door and any approaching individuals..
Any general recommendations? Where’s the best location to make sure you get a good shot of the face?
Thanks!
Thanks!
you could always use 🦆 tape on the mounts to stick them up for testing placement and just use the old tride and true trail and error untill you get them in a location that works best for your situation.
If You Got Em....I'll Chew Em!
Netgear & Arlo Beta Tester
read this ; https://kb.arlo.com/37/How-do-I-position-my-Arlo-Wire-Free-or-Arlo-Pro-Wire-Free-camera
I found that it works to set my sense level to set to about 95% and then each day lower by 1% until the false trigger ( alerts ) stop.... prob around 90% or lower for the best response
Each location is different
