I want to record a long segment (several hours) from a CVR clip with a screen recorder while playing a clip. My arlo account keeps logging out after 30 minutes because it is "inactive" even though a clip is actively playing. Does anyone know how to not get logged out?
Thanks.
It's been a while since I tried but when viewing CVR it didn't use to log you out. No interaction with the interface will cause a logout otherwise. Are you actually watching CVR for >30 minutes and having it log you out or are you just concerned that you will get logged out?
I guess a workaround for the former would be to make multiple recordings, each 30 minutes long, resetting CVR to the point it stopped to start a new one. Then use an editor to combine them. You might want to make sure the videos have some overlap to make the finished product seamless.
