I have recently segmented my network so that I have a separate isolated Guest/IOT network. I want to put all of my IOT devices on that network. Is there a way to force the base station to renew its DHCP lease so that it will pick up an address from the guest network? Before I do this I will reconfigure the port on the ethernet switch so that only that network appears on that port. I know that the base station can't recognize a VLAN tag.
See my edit above. I can do it at the command line on the router.
Thanks.
You can't configure the base in any way so you have to do it on the DHCP server end. If nothing else, you could use a WiFi switch set to turn off and back on at your desired times.
I don't want to "configure" the base. I just want it to ask to renew the DHCP lease like it does when the lease expires normally expires. I guess a complete reset would do it but I would have to go through the whole setup again. Everything is already setup on the server end.
Actually scratch that...
I just found there are command line commands for the Ubiquiti edgerouter which will force a dhcp release/renew.
Not gonna happen since there's no way to configure network parameters on the base.
Thanks.
