  • 7 Replies
  • 2810 Views
  • 2 Likes
  • 5 In Conversation
EVISPI
 Buffering.. When I go to My library I can see all the videos there for recordings. For the last 2 days when I click on a video all it says is Buffering.  It never opens the video. Anyone else having this problem?
EVISPI
Hi james, I use the arlo app on my phone. I fixed it.. You know that fix every IT person tells you to do first, power it down and power it back on LOL.  Thanks for chiming in.
7 REPLIES 7
EVISPI,
Are you using the web client or the Arlo Secure mobile app? If you try logging in to your account using a different device, do you still experience the same behavior?
EVISPI
MP101
Trimmers accidentally cut computer cable.  Comcast repaired cable.  Now I am
unable to view clips from library due to buffering.  Clips won't load for viewing.  I have
turned off camera and back on.
MP101
I did unplug from power strip and router.  Waited cpl minutes & plugged everything back in.  The clips show up in the library, but when I attempt to view one, it
remains in 'buffering'.
Rather sounds like a Comcast issue but try rebooting your router and base, in that order, first. Any luck?
EVISPI
Yup that's what I did I rebooted.. thank you.. Then took the other person's suggestion and now I wait about 15 seconds before. I put the new battery back in before I would do it really instantly. I think that was causing it not to connect properly
DEBBIEB1952
I was able to resolve the issue by turning off my wifi and using my smartphone data.  Worked liked a charm and only thing I had to do.
I cannot explain why this just recently started but....appreciate this forum where I could get straightforward suggestions quickly.
Frustrating that I only have to do this with my Arlo video captures, but...it works so I'll take the win!
  • 7 Replies
  • 2811 Views
  • 2 Likes
  • 5 In Conversation
