Pro 4
  • 1 Reply
  • 1255 Views
viewdwsc
What is the best way to mount an Arlo Pro 4 and Solar Panel on a rain gutter? The camera has a anti theft mount.  I see tandem mounts on Amazon, but reviews say they can't connect to Pro 4 or are not reliable.  Thanks in advance.
There are many gutter mounts found in a quick Google search but the security mount may be an issue. If you want to change to a standard case, check here for possible solutions:
https://www.arlo.com/en-us/accessories.pro3.pro4
I've also mounted directly to the gutter by drilling holes as appropriate (maybe only for 2 out of the typical 3 mounting holes since all I can do is a straight line rather than a circle of holes).
  • 1 Reply
  • 1255 Views
