  • 6 Replies
  • 2609 Views
  • 6 In Conversation
shoebox303
Hi there - brand new here and looking to purchase some Arlo Pro 2 cameras. They will all be outdoor cameras. Can someone explain the difference between the included wall mounts and the optional "security" wall mounts for me?  Thanks!
6 REPLIES 6
Look at PRODUCTS / accessories
https://www.arlo.com/en-us/products/default.aspx?p=prodarlo_pro_2_systems
Wklovelace3
Virtuoso
Virtuoso
The magnetic ones are for indoors. The security wall mounts screw into the back of the camera making it harder to steal
emgolsch
I just purchased the Arlo wire-free HD security camera for outdoor use. Is it correct to assume that the magnetic wall mount can be used outdoors at least temporarily until we purchase the mounting arm? Thank you.
Yes. I've used the magnetic base outdoors for years.
Mgcaekdb
Do you have them up high?
Typically about 8 feet up from ground level.
  • 6 Replies
  • 2610 Views
  • 6 In Conversation
