Bought 2 new arlo pro 2 cameras
Fully charged and phone cannot find devices to add the 2 cameras
Base is connected to internet
Please help
13 REPLIES 13
If you have a base station with the button on the top, try pressing it for two seconds then press the camera top sync button.
Try using a PC web browser instead (my.arlo.com).
Are these new or used?
I tried that
I tried that and it did not work thanks for trying to help
They are new. Thx
do not hold the base button.... a quick press and then the camera.
Move your base as far away from yr router ( length of cable ) and then hold the camera about 3 ft away from base
do you get a slow blinking blue led to fast on camera?
Ok ill try that. Appreciate it. Im out and about so ill do this later
Should i sync the camera to the base 1st then try to find the device on my phone?
Sounds dumb but I'm trying everything lol
sync first... if it syncs by showing fast blue led flash.... closing/reload app and it should appear on app
@Bmachi03 wrote:
They are new. Thx
Then I suggest trying support next. Use the link at the top of the forum page.
Thx...i synced them this am but the phone wouldn't find the new device
Thx for help
Thx for help
Are you seeing them in the web browser (my.arlo.com)? If so, can you live stream?
My.arlo.com cant find my base station
And the phone doesn't either?
