Both Arlo Pro 2 Cameras will not charge. App says they are off line. Both worked 2 weeks ago
Have you tried these steps: https://kb.arlo.com/000059145/My-Arlo-Pro-or-Arlo-Pro-2-camera-battery-isn-t-charging-what-do-I-do ?
Yes, tried all the steps listed in forums.
There are some other steps here you might not have tried: https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
If this second procedure doesn't work, you probably should contact support: https://www.arlo.com/en-us/support/contact.aspx
Did you solve the issue? Ii still can't make the batteries charge... it is asking me to replace them, but they were workeing perfectly until I updated the APP in my phone.
HI @fernandots
Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
