  • 6 Replies
  • 1661 Views
Ricochet55
Both Arlo Pro 2 Cameras will not charge. App says they are off line. Both worked 2 weeks ago
6 REPLIES 6
Have you tried these steps: https://kb.arlo.com/000059145/My-Arlo-Pro-or-Arlo-Pro-2-camera-battery-isn-t-charging-what-do-I-do ?
Ricochet55
Yes, tried all the steps listed in forums.
There are some other steps here you might not have tried: https://kb.arlo.com/000052305/My-Arlo-Pro-or-Arlo-Pro-2-battery-is-dead-what-do-I-do
If this second procedure doesn't work, you probably should contact support: https://www.arlo.com/en-us/support/contact.aspx
fernandots
Did you solve the issue? Ii still can't make the batteries charge... it is asking me to replace them, but they were workeing perfectly until I updated the APP in my phone.
ShayneS
HI @fernandots
  Please contact the Support Team to further investigate this issue. You will find several options for contacting support in the provided link. Arlo Tech Support
Ricochet55
Cameras still both dead. Need to contact Arlo support live. Don't know if batteries or cameras not functioning.
  • 6 Replies
  • 1662 Views
