  • 4 Replies
  • 1696 Views
MargaretArlo50
 I have 3 cameras that I have installed outside my 1500 sq foot house. They are connected to my wifi. the one that is the farthest away looses it's charge within 4 days. The other two last weeks. What do you think is wrong?
ShayneS
Hi @MargaretArlo50
How long has this issue been occurring with the camera?
May I ask which troubleshooting steps you have performed so far? I don't want to suggest any prior methods you have previously performed.
MargaretArlo50
This issue has been present from the start from this location. When I
have the camera recharged and in the house, not as far away from my
router it does not wear down the battery near as quickly. I have also
switched out the camera with another including battery and the same
thing happens from this location. I think I may need a booster
ShayneS
This sounds like there may be a clear range issue. Have you tried to move your base station from any electronics that may cause interference? I have provided an article that has a bit more information pertaining this topic. How far can I place my Arlo wire-free cameras from the base station?
Or due to size of home( also type construction ) / range of cameras, you may need a second base ( it is the only true way to expand coverage area )... there are no limits on the number of bases used on any account.
  • 4 Replies
  • 1697 Views
