My camera has been charging for an hour now and it is not moving from 11 %. I use original cable that came with the camera.
How do I resolve this?
It is also showing error “faulty charge has been detected” in live view window
This is error I see while camera is plugged.
Pull battery and then replace, attempt to charge again ( resets camera )
If you have more than one battery pack, try swapping with another camera to eliminate a bad battery ( see if the issue follows the battery )
You say the original cable, but are you using the ac adapter too ? ( requires a dual voltage charger to charge )
Tried that already 🙂
Tried re-synching no luck
removing device no luck
different charged no luck
Contact Support https://www.arlo.com/en-us/support/contact.aspx
