Power Arlo Pro 2 with 12v, low voltage landscape wiring?
  • 1 Reply
  • 2189 Views
awesomes007
Hi All!
I want to place a camera out on a lamppost.  There is no easy access to the 110v but it has 12v low voltage landscape wiring.  I'm wondering if I could somehow power/charege the camera with the low volt?  Maybe if I put in a 12 to 9 volt coverter?
Thoughts?
Thanks!
JBP
Streak2
Master Master
By the time you have finished trying to get from 12VAC to the correct DC voltage for the camera a better bet would be to use the Arlo solar panel.
https://www.arlo.com/en-us/products/arlo-pro/solar-panel.aspx
  • 1 Reply
  • 2190 Views
