  • 6 Replies
  • 1754 Views
DJ6
What is going on with battery draining yet cameras being used as much or even less? We are thinking some “change” to software happened to cause this massive draining. Batteries would last a month and now we are lucky to get a week! Hey, Arlo please fix!
6 REPLIES 6
No problem here. Any chance something that also uses the 2.4GHz band has been installed or moved close to the base? Signal strength and/or quality can dramatically worsen battery life. I'd also suggest moving the base as far away as practical from the router.
DJ6
Nothing done except changed to better internet service.  Arlo app has stopped giving notifications yet I have them “on.”  It also puts singular cameras offline constantly thus missing valuable recordings.  I feel Arlo is not improving their older models as they need more revenue so they make the old ones do these things to get you to buy newer where you pay for storing your personal videos.  We have a different camera system at our rental and it works incredibly! We are guess being forced to say goodbye yet we were faithful customers for so long.  Sad when companies don’t care about customer service.  The only response is in this community board.  They need to read the book, “Who moved my cheese?”
I read that book many times.
While there's no guarantee of success, you may want to remove all devices from your account and start fresh. However, if you have a VMB4000 base, that may prove problematic  based on various reports here. Still worth a try. You could purchase a SmartHub (I'd suggest the VMB4540) to replace your old base which may work better.
Timetoscuttle
I have the same issue as noted here and I have the base station you recommended to upgrade to (VMB4540).    I have also noted that the difficulties began after changing our network provider and going to a higher speed.   I find it reprehensible that Arlo is not addressing this issue when you can see it being discussed frequently.    I have spent much time on the phone with them as they have attempted to resolve the issue to no avail.   I think it's time to scuttle the ship and move on to another company.
Network changes generally don't make a difference as long as the ISP isn't blocking sites/ports. However, the new hardware may be affecting the signal from the hub (maybe a stronger signal from the router?). Try moving the hub as far away from the router as practical to see if things improve.
Timetoscuttle
I will attempt to move the base station further away from the router.   Currently they are within inches of each other.    The maximum I will be able to achieve is the limit of my cord which appears to be about 4 feet.   Do others that have camera systems without the base station suffer from these frustrations?   Thank you for your response.
  • 6 Replies
  • 1755 Views
