Base station vmb3500
Base station will not power on even after going through troubleshooting steps.
Is he base supplied with 12vdc from the wall socket adapter?
Do you get any LEDs showing activity when you apply power to the base?
You can use a voltmeter to check the power supply connector for 12 volts DC.
