@jguerdat wrote:
Firewall could do it but if it's an ISP-owned device they may have to be the ones to fix the issue. Ports 80, 123 and 443 to arlo.com must be open.
Port 80 and 443 are used for http/https. Port 123 is used for ntp time sync. No ISP will block those ports.
Some enterprise class firewalls might proxy them (and potentially selectively block them). If you have parental control features enabled in your home router, you could try disabling them.
First, what are the base LEDs showing when "offline"? If all are green, it's not your system. Try force closing the app and open again as well as using both cell service as well as WiFi. Try a computer browser.
No issue with the app at all. Just the base station itself.
I also have reset the base station, removed all devices from my profile... then added them all again as if brand new from factory. No change 😞 base is still offline intermittently
@BirdieTurkey wrote:
Green, solid amber, green,
Might be worth contacting support. https://www.arlo.com/en-us/support/contact.aspx
Amber means that ethernet is working, but that the base isn't reaching the internet. Did you just switch to a new modem, or did you actually change to a new internet provider? Do you have any other devices connected to the modem/gateway using ethernet?
One thing you could do is look at the modem/gateway's attached device list, and see if the base is shown there.
Thanks for the replies!
Have you rebooted both the modem (is it a modem/router or separate? If separate, reboot both) and the base, in that order?
