Base Station Won't Turn On #VMB4000
Everythig was working fine...but I unplugged it to untangle some cods behind the tv, plugged the base station back up and now it wont power on. The 3 ambers lights flash briefly and that all. It wont power on fully. Why is this? What do i do?
Make sure the socket is working and that all power connections are tight and fully seated. If all seems fine, open a case with support for warranty replacement:
Thanks for responding! Ive tried everything, ive moved it to other sockets and even found a power adapter with the same specs but to no avail. I here a timer, like a ticking watch inside the base station and every time it ticks, the amber lights flash but thats it. Thansk for your help again!
