Arlo solar charger stopped charging my battery (battery works fine when plugged in).
There was a recent thread about connectors having pins pushed in so wouldn't make the connection to charge. You might want to look carefully on all ends to verify no damage. Since these panels have connectors both to the camera as well as to the panel, disconnect both ends to see if that helps.
