  • 1160 Views
Khademul02
Arlo pro2 camera is not connecting to VMB4540 smart hub? Could you please help me?
Details. What have you tried and what do you see? What is the hub LED showing? Exactly what procedure are you following?
Khademul02
Hi , Thanks for reply. I followed the app. After connecting hub, I tried to sync camera as per app instruction. Both camera and hub blue lights are blinking but after one minute it is showing no camera found. I tried again and again but no outcome. I also tried after resetting the hub but same problem.
Remove and reinsert the camera battery. Try briefly pressing the base sync button - don't hold it for 2 seconds and then the camera button. Any better?
  • 1161 Views
