  • 2 Replies
  • 2066 Views
cnewma4c
I just purchased a 4 pack arlo pro2 and am already seeing posts about compatibility problems between arlo and uverse (rg nvg589). Are these systems compatible or will I be wasting my time with setup? Thanks in advance on advice
The easy thing to do is to plug the base into power and the router and try. Either the Internet LED turns green or it doesn't.
cnewma4c
Looking good so far, guess all the kinks are out. Not same experience I had with seeting up cloud and uverse which was painful experience.
  • 2 Replies
  • 2067 Views
