Arlo pro 2
  • 1 Reply
  • 819 Views
Jomg
I just updated my Arlo app. Big mistake. Now I have no library option to select all to delete or filter. Is it possible to get the older version?
Do you now see Feed to view recordings? If so, click on the 3 dot menu at the top right and select Manage Events. This allows you to select videos to delete. Otherwise, Feed Settings is where you can filter videos. You can also look at just one camera's videos by selecting that camera in Dashboard (if you have a widget for it set up) or Devices.
  • 1 Reply
  • 820 Views
