Solar panel purchase help
What solar panel will work with arlo pro2?
I can’t find the specific arlo pro 2 solar panel but see other arlo solar panels ?
I have bought off brand and all they do is drain battery !
thank you
The Arlo part was the VMA4600.
I say "was" because Arlo no longer sells them. You might be able to find old inventory (or used) somewhere.
