I have 4 Arlo Pro 2 (H3) with a base station (VMB4000r3). I also have Arlo Pro 4 (H4) which is also connected to the base. I had a paid subscription for a year. Now the subscription is expired. Now 3 of my Arlo Pro 2 are saying a paid subscription is required to activate the device. I can't even see the live camera. I thought Arlo Pro 2 have 7 days of free recordings and no need a paid subscription to use them. Not sure what is happening. Reboot the base station and still having the same issue. Any help is appreciated. On the other hand, I can still see all the cameras via Apple Home.
All resolved. This is what I did. removed one camera from the group. And then go through the syncing process to add it again. Somehow all the cameras are working again and started recording.
7 REPLIES 7
There is a limit of 5 unsubscribed cameras in the account (that has always been the case).
You list 5 cameras total - is it possible there is another one in the account?
Only 5 cameras. Nothing else. Right now, 3 Arlo Pro 2 cameras are saying I need subscription.
Did you set up activity zones? Those require a subscription. If so, remove the zones to remove the message.
I don't even have a menu to delete those activity zones anymore. Except the working ones (Arlo Pro 2 and one Arlo Pro 4).
For those two working ones, activity zones are all deleted as well.
@pyi Thanks for the update!
